Management profile has been removed from device
kevin36
I was curious to know about the functionality of the some of the commands in the dashboard. I had a spare iPad and decided to see what 'Erase Device' did. Now in bold red print at the top of the device info page it says 'Management profile has been removed from device'. I am assuming by management profile it is referring to the System Manager. To my understanding, you can add that back to it, but it needs to be done from a Mac?
Just trying to verify that I have not made the device permanently inoperable.
Thanks for your time,
Kevin
1 Reply 1
vivification
Yes it will be referring to the System Manager app, which is the agent installed on the iPad. Obviously erasing the iPad removes the management agent so you will see that.
To install it back - you essentially are re-provisioning the iPad, and re-enrolling it, so if you left the entry in the Device Manager when you erased it - it will re-sync/checkin etc.
