MacOS 15 and Security Policies
Kevin_G
Hello dear Community,
yesterday we upgrade some MacBooks to MacOS 15. Everything works fine. After 3h the Security Policies said that the devices are not secure anymore. The Problem seems that the agent does not send that there is a Firewall installed on the devices.
We use Sophos Endpoint version 2024.3.0.x.
the other MacBooks still run on 14.6.1 and everything works.
Does anybody have the same problem and maybe a solution?
Thanks for help
Kind regards
Kevin
12 Replies 12
ConnorL
Meraki Employee All-Star
macOS Sequoia changed how applications (such as the SM agent) can determine if the firewall is enabled. https://developer.apple.com/documentation/macos-release-notes/macos-15-release-notes#Deprecations
I'll check with the SM team when we can expect a new agent version that adds this support.
Kevin_G
Thanks for replying. so we need to wait?
Iannand
Just browsing
It seems like the security agent isn't fully compatible yet with the new OS. In my case, I had to manually reinstall the firewall settings and re-verify the device with the security tool.
Kevin_G
Thanks for reply. At first we tried to reinstall the Endpoint Protection. no change.
ConnorL
Hey @Kevin_G,
I've flagged this to our SM-PM team for their awareness. I don't have an ETA of when this will be resolved but I'll keep you updated as soon as I get any info.
Cheers, Connor.
Kevin_G
Thanks Connor. we will wait for an update.
Best regards
Kevin_G
Hi there. Any Updates?
ConnorL
Unfortunately, I have no updates to share at this time.
Kevin_G
Hello There, is any update in plan? or do i need to open a case?
ConnorL
Feel free to open a case, this helps with priority and scale of impact. The Support Engineer will assign the case to the bug I forwarded to Engineering.
Kaitlin
Just browsing
Hello, I am having the same issue as Kevin_G above. I am wondering do I need to open a case as well? Thank you!
ConnorL
