- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Mac OS device enrollment - Unable to remote desktop
I've just enrolled two Mac OSX devices into my SM network. I've enrolled via the standard web page enrolment as well as downloading the agent/package and installing on the devices.
Devices are checking in to dashboard and are online and showing up to date. I'm however unable to remote desktop/use any of the advanced features which should be enabled with the agent/package install.
How do i enable these features? I've tried to download the agent several times however still having no luck.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Checkout the page below. Would say your firewall is blocking some outbound traffic which is causing the problem. Ports 993, 7734 and 60000 - 61000 are required for systems manager to work correctly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@BlakeRichardson Thanks Blake, only problem is that there isn't a firewall in the way of these devices.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have you setup these devices yourself as there is a way for remote desktop to be blocked on client machines.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hey @BlakeRichardson, Managed to get to the bottom of this one. My devices had AV's installed which appeared to have a built in host firewall. Looks like these were blocking some of the outbound ports required 🙂
Cheers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Awesome glad you worked it out!
