MDM ipad question
abcdef12345
MDM ipad question
Hello community.
please understand i'm not good at english.
because english is not my first language.
our customer is going to esim(data internet) insert to ipad.
at this point i have some question.
i'm already known that is enrolled ipad in MDM, only Supervised IOS device limit Content filtering config in Safari.
if Content filtering config, then there are same apply both WIFI and esim?
and last question
is there limit open application config esim or WIFI?
i find document and check context, there is only hide config.
thanks for reading.
KH
Hello @abcdef12345
Meraki Systems Manager MDM should work the same whether you are using an eSIM, Wi-Fi, or otherwise for connectivity so content filtering should work just like when using Wi-Fi. Functionality of the MDM should function the same whether an eSIM or Wi-Fi is in use, so if you are able to limit open application config on Wi-Fi, this should also do so via eSIM.
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
abcdef12345
thanks for reply.
if there is limit to open application config on mdm?
can i get to document url?
thanks
PaulF
Whilst you can't prevent the opening of an application on iOS, you can certainly hide and application using a restrictions profile
