MDM: iOS device types
MFuchs
Hi !
I need to separate iOS devices by iPhones and iPads.
Until now i did that by tagging iPads manually.
So i would need to tag iPhones manually, too.
The goal is to roll out apps only for iPhones or ony for iPads.
How do others do this ?
Sadly there is no functionality to filter from devicetype like iPad or iPhone, although meraki mdm knows about this device type in the dashboard (model field).
3 REPLIES 3
BlakeRichardson
@MFuchs  We tag our devices the same way i.e. iPad, iPhone, Laptop etc. As far as I am aware there isn't any form of auto-tagging this it just part of the process of setting up a device.
Meraki breaks down the devices types as shown below but doesn't get anymore granular than that.
www.btr.net.nz
T1
You could do it via API and a simple script.
1. Fetch a list of devices.
2. Filter out iPads/iPhones that don't have a tag you want.
3. Assign tag(s).
Something like below. It's written in powershell but requires curl to make API calls. One of my early scripts, still works so I never bothered rewriting in pure powershell.
# Curl
$curl = "c:\curl\bin\curl.exe"
# Meraki API headers
$api_key = 'X-Cisco-Meraki-API-KEY: XXXXXXXXXXXXXXXX'
$content_type = 'Content-Type: application/json'
# MDM network id
$network_id = 'XXXXXXXXXXXXXX'
# Log file
$log = 'C:\Scripts\Scheduled Tasks\Tag_assignment_log.csv'
###### Fetch the list of devicess ########
$uri = "https://dashboard.meraki.com/api/v0/networks/$network_id/sm/devices?fields=ip,systemType,lastConnect..."
$list = (@((& $curl -L -H $api_key -X GET -H $content_type $uri) | ConvertFrom-Json)).devices
# Filter iPhones without my_iPhone_tag tag
$iphones = @($list | where {$_.systemModel -match "iPhone" -and $_.tags -notcontains "my_iPhone_tag"})
# Add missing my_iPhone_tag tag
foreach ($iphone in $iphones) {
$binary = '{"ids":"' + $iphone.id + '", "updateAction":"add", "tags":"my_iPhone_tag"}' | ConvertTo-Json
$uri = "https://api.meraki.com/api/v0/networks/$network_id/sm/devices/tags"
& $curl -L -H $api_key -X PUT -H $content_type --data-binary $binary $uri >> $log
MFuchs
Hi !
Thanks your quick replies to my question !
I'm stuck in a datacenter move, so I'll try this afterwards.
But that's exactly the right idea for what I'm trying to achieve, so thank you very much in advance !
