Lock device on multiple devices
RGrayTpT
Can I enable "lock device" on multiple devices simultaneously? Please advise, thanks!
PaulF
Not though the UI, although I'll feed that back, but it is available through the API:
https://developer.cisco.com/meraki/api-latest/#!lock-network-sm-devices
RGrayTpT
Thanks! I've never used the API...how would I go about doing this?
PaulF
So, this particular API is relatively simple to use. In fact, using the link above, you don't even need to write a single line of code!
This is a good place to start: https://developer.cisco.com/meraki/api/#!getting-started/base-uri
For the lock devices API call: You'll be able to do this through the UI itself...
You'll need:
  • API key
  • Network ID
  • device IDs
