How to Restrict Users from changing iTunes account
Baldguy_2018
Just browsing
Good Morning all,
I've got a fleet of iPad's were we use the same corporate iTunes account on them.  We've removed the App Store from the configurations, but we would like to restrict the users from being able the change the accounts.  This feature was in iOS 11 under General, Restrictions, Accounts, and selecting Don't Allow Changes.  But I can't seem to find this in Meraki and to top it off, iOS 12 moved it Under Screen Time.  Any suggestions?
MikeMandalorian
Under Screen time ( you also have to have a Screen time passcode set in place , if you don't want the users to change anything so i wouldn't recommend it set to the same code to unlock the device  , select  Content & Privacy Restrictions, turn on Content and privacy restrictions , then under ALLOW CHANGES under Privacy  it has Account Changes  select Don't Allow
jared_f
I am not positive of this so please correct me if wrong. Couldn't you uncheck and push "Allow modifying account settings (iOS 7+)" profile? The nice thing is that you could login with the Apple ID during setup (DEP) or even with manual enrollment (m.meraki.com) and then the option would be restricted. Seems way better than going to each device and trying to keep track of restriction passcodes. Screen Shot 2018-09-26 at 5.06.37 PM.png
Baldguy_2018
Just browsing
Thank you for the response Jared.
Unfortunately, that didn't work with iOS 12.  The option to not allow any account changes was moved to Screen Time -> Content & Privacy Restrictions -> Account Changes.
