Exporting Tags
jtech484
Exporting Tags
Is there a way to export all tags (ie. User, Device, Policy)
BlakeRichardson
You can add more columns by clicking on this button, any info you add will also be added to the CSV export so you can export the owner this way.
Re Installed Ap's I'd need to research this.
BlakeRichardson
Yes it is, you simply click the CSV button and all of your tags will be included in that export.
jtech484
Thanks @BlakeRichardson -  had a 'Duh' moment there.
Also, how do I export a list of tags for:
  • Systems Manager / Configure / Owners
  • Systems Manager / MDM / Apps
I don't see the CSV option is not there?
BlakeRichardson
jtech484
Thanks Blake,
That did the trick, I'll mark it as the solution.
Please let me know if you do find a way to export a list of the apps. Thanks again.
-Jay-
