Is there a way to enable the iphone feature Do not Disturb while driving? Either to push it out under a Tag or profile setting
Solved! Go to solution.
No, user settings need to be manually set on the device.
Sounds like something iOS should do rather than Meraki.
As of this post, nothing has changed. Apple has no method for MDM to control this feature.
If desired, please file apple feedback:
https://www.apple.com/feedback/
This question came up recently, I'm making this post to confirm that this is still the case.
