Disabling Apple Relay in Systems Manager
kvv
I have been suggested to disable devices from using Apple Relay instead of trying to open it up right now on our firewall.  Is there a setting in Systems Manager that I can disable iPads from using Apple Relay?  It should be a setting to "Turn Private Relay off" but when searching for this, I cannot find that setting.
1 Reply 1
BlakeRichardson
The only way I can think of doing this is by disabling iCloud full stop. I haven't seen a MDM payload specifically for Private relay.
Edit : Apple does support this but I suspect it hasn't been implemented into Meraki SM yet.
https://support.apple.com/en-nz/guide/deployment/dep739685973/1/web/1.0
