Device lock command
TheBarge
Device lock command
Hi Guru's, We have this issue with the lock command being pushed, on the records, logs it says it was pushed and successfully set up but contrary the device is not totally locked.
1 REPLY 1
Shany
I understand that the lock command is the same function as pressing the sleep button on the iOS device.
If the log shows that the lock command push has been successful, the device's screen turns off and changes to a lock screen.
To verify this, you will need to wait and see if the screen on the device does not turn off.
I saw this function working before.
