Cisco System Manager is blocking the installation
Hassen
I have a device with Cisco System Manager installed, I'm trying to install an app on this device through a link, but Cisco System Manager is blocking the installation process, how can I, through Cisco System Manager, allow this app to be downloaded on this device
1 Reply 1
PaulF
@Hassen
Firstly, what's your device type? If Android, you HAVE to be explicit with regards to restrictions: For a fully managed device, if you haven't put a restriction on the device to ALLOW the installation of apps, then you won't be able to install apps
