Cannot install education payload on iPads
JCarey
We have iPads in the school and use Meraki to push the education payload linked with ASM. Over the weekend, it seems this was broken and we now get an error message:
Code: 1000
Domain: MCProfileErrorDomain
Error: The profile "Profile Name" is invalid
Error: "The payload "Payload Name" is invalid
Error: A user with the identifier "strong string numbers" could not be found.
I called Meraki and they don't know what's going on. They are escalating. Any thoughts?
SoCalRacer
Have you verified the cert is good?
Have you checked the time is correct on the iPad before deploying?
Yep. Verified cert and tokens are all good and sync is working.
Are you managing the domain/cert with IIS internally?
LluisRD
This sound that APPLE DEP servers are wrong
Check in MERAKI MdM
Organization -> MDM
       Apple MDM push certificate  -->  Test Certificate
       Apple DEP Servers --->Token Expire ????
       VPP Account --> Token Expire ???
Attention: I suppose the same meraki network and good profiles
Regards
