Cannot get rid of old devices
BlakeRichardson
If I apply some settings to all devices I get in that list a load of devices that are no longer in my dashboard, these were DEP enrolled devices that have even been removed from DEP,
If I clcik on one of the device names I get the below error.
How can I remove these as they are not helpful when it comes to keeping an eye on a profiles deployment rate.
BlakeRichardson
It turns out that even if you delete devices from your network but they are still loaded into your DEP then they are still technically in Meraki so will show in any settings profiles they were scoped to before they were deleted.
Once you remove them from your DEP (only do this if you are disposing obviously) they they disapear from Meraki. The other alternative is remove any tagging from devices before you delete them.
To me this just seems like bad programming but what can you do.
BlakeRichardson
I have checked to documentation and it makes no mention of having to un-scope devices.
  1. Log in to Dashboard, and select the appropriate SM network.
  2. Navigate to Systems manager > Monitor > Devices
  3. Mark the checkbox for each device to remove.
  4. At the top of the Client list, select Delete > Remove from Network
BlakeRichardson
T1
I have always been under the impression that to remove DEP enrolled devices from the network, you need to "Unassign settings" under Systems Manager > Manage > DEP. Which is direct opposite of enrolling them by "assigning settings" in MDM which consumes a license and activating the device establishing the link between the two.
Deleting them from the devices list works for other types of enrollment,
