Can users access self service without logging in?
kaiser_sosea
We've recently transitioned from JAMF to Meraki and have made some assumptions as to how Meraki might behave based on JAMF experience.  For instance; with JAMF each enrolled device can get the self service portal which is handy to give users the ability to force the install of an app or remove and re-install if there are issues.  Does the Meraki Self Service portal work the same way?  Is there a way to bypass forcing users to login as it is assumed if a device is enrolled it is in fact licensed and able to install the appropriate apps, etc..?
1 REPLY 1
Inderdeep
@kaiser_sosea : Go through it
https://documentation.meraki.com/SM/Other_Topics/Systems_Manager_Self-Service_Portal
Regards
Inderdeep Singh
www.thenetworkdna.com ( Awarded by Cisco IT Blogs award 2020)
