We've recently transitioned from JAMF to Meraki and have made some assumptions as to how Meraki might behave based on JAMF experience. For instance; with JAMF each enrolled device can get the self service portal which is handy to give users the ability to force the install of an app or remove and re-install if there are issues. Does the Meraki Self Service portal work the same way? Is there a way to bypass forcing users to login as it is assumed if a device is enrolled it is in fact licensed and able to install the appropriate apps, etc..?
