[BUG] 'Orphaned' Webclips cause Homescreen Layout to tank
MarkFord
Turns out if you define a homescreen layout that includes webclips for iOS devices, and later on delete the Webclip Setting BEFORE you delete it from the homescreen layout, it causes a bug.
Everytime you try and delete the webclip from the homescreen layout it deletes every application proceeding it one by one but doesn't actually remove the webclip.
Only 'workaround' I've found is completely removing the layout setting and starting again fresh.
Fun time, I'll get back to rebuilding this setting from zero then.
If you wouldn't mind have a peak at this one C.M team, that'd be great.........
0 Replies 0
