Autoscoping tags based on OS version
jm_peterson
Is it possible to scope a tag to devices on a specific os version? Such as 10.13.x get “Tag A” and 10.14.x get “Tag B” from Systems Manager?
6 REPLIES 6
MikeMandalorian
Oh i really hope someone knows how to make this work because this would be awesome
vassallon
@jm_peterson The closest I can think of to accomplish this is through security policies based on minimum OS version.
This would apply policy tag to each device.
@vassallon It was definitely a good idea. But it appears the security policy cant scope worth a damn and returns this. Screen Shot 2019-04-16 at 2.25.56 PM.png
What about if you add in these options for Mobile Security?
@vassallonUnfortunately that didnt work. I was looking for a way to automate this for Mojave so custom pppc/tcc/kernel extensions could be applied as users update. Since there is no solution I threw one together.
Disclaimer, python is not my strong suit so there is probably a more efficient way to do this but this is working for me.
You just need to replace YOURSMNETWORKID with your network_id, yourreallylongapikey with your api key, and the tag name with whatever you want the tag to be.
Hopefully this is of use to someone. ¯\_(ツ)_/¯
import requests
import json
meraki_url = 'https://api.meraki.com/api/v0/networks/YOURSMNETWORKID/sm/devices'
aki_key = 'yourreallylongapikey'
search_models = ['OS X 10.14', 'OS X 10.14.1', 'OS X 10.14.2', 'OS X 10.14.3', 'OS X 10.14.4', 'OS X 10.14.5']
meraki_payload = ""
meraki_headers = {
    'X-Cisco-Meraki-API-Key': aki_key,
    'cache-control': "no-cache"
def tag_the_machines (serial_input):
    url = 'https://api.meraki.com/api/v0/networks/YOURSMNETWORKID/sm/devices/tags'
    args = {
        "updateAction": "add",
        "tags": "Mojave",
        "serials": serial_input
    payload = ""
    headers = {
        'Content-Type': "application/json",
        'cache-control': "no-cache",
    try:
        r = requests.request("PUT", url, data=payload, headers=headers, params=args)
        r.raise_for_status()
        print ("Tagged" + '' + serial_input)
    except requests.exceptions.HTTPError as err:
        print (err)
def check_key(dict, key):
    if dict.has_key(key):
        global batch
        batch = dict[key]
    else:
        print ("Batch not key present")
def get_all_machines ():
    url = meraki_url
    payload = meraki_payload
    headers = meraki_headers
    r = requests.request("GET", url, data=payload, headers=headers)
    global all_machines
    all_machines = r.json()
    check_key (all_machines, 'batchToken')
    create_mojave_dict()
def send_batch_request ():
    url = meraki_url
    querystring = {
        "batchToken": batch,
    r = requests.request("GET", url, data=payload, headers=headers, params=querystring)
    global all_batch_machines
    all_batch_machines = r.json ()
    create_mojave_batch_dict()
def create_mojave_dict ():
    serial_number = []
    os_name = []
    for m in all_machines["devices"]:
        serial_number.append(m["serialNumber"])
        os_name.append(m["osName"])
    machine_dict = dict(zip(serial_number, os_name))
    global mojave_machines
    mojave_machines = []
    for s in search_models:
        for k, v in machine_dict.items():
            if v == s:
                mojave_machines.append(k)
    for m in mojave_machines:
        tag_the_machines(m)
def create_mojave_batch_dict ():
    serial_number = []
    os_name = []
    for m in all_batch_machines["devices"]:
    global mojave_batch_machines
    mojave_batch_machines = []
            if v == s:
                mojave_batch_machines.append(k)
    for b in mojave_batch_machines:
        tag_the_machines(b)
if __name__ == '__main__':
    get_all_machines()
    send_batch_request()
BlakeRichardson
@jm_peterson  The overview section of systems manager will show a break down of OS versions, you could manually click on each version and apply a tag that way. You would have to constantly keep it up to date though.
