AutoTag for DEP enrolled devices
_aDiedericks
Hi there,
I'd like to know if there is functionality that automatically tags devices that have been enrolled into Meraki via DEP or can be created, customized to indicate a DEP enrolled device vs a manually enrolled device?
I don't see how Meraki could know this information.  DEP is a process that Apple uses to determine which MDM to point a new device at.
I think all that Meraki sees is a device checking in to be provisioned.
4 REPLIES 4
Thanks for your response. We've resorted to tagging all devices in DEP manually with DEP tag
BlakeRichardson
You can apply default tags in System Manager > Configure > General
By default the tag is "recently added"
www.btr.net.nz
PaulF
So, as each device enrolled through DEP will also be Supervised, you can look for:
You can also, in the device list, hit the + button and choose "Supervised" or "DEP Enrolled"
if you want to search between the two enrollment types
