Asset Tag Upload
Ranger-Smith
Asset Tag Upload
I am having a problem doing a bulk update of the notes field using a CSV. I have done it for the last 2 years when we get our new batch of iPads for the school year, but this year it doesn't seem to be working any help would be great
Ranger-Smith
Same Issue again this year anyone have any advice or need more information from me.
vassallon
I've never tried updating notes through a CSV file. I have tried updating owners and if the CSV file was too big, the process would fail.
How many are you trying to do at once? If I remember right I had to keep it at about 200 or less to make sure it would complete.
Ranger-Smith
I found what the issue was. I believe it had to do with downloading the csv from a google sheet. If I made a CSV and copied the information into the file it worked even if I tried to do 550.
vassallon
Glad you were able to get it squared away. I wonder if some non-standard character was getting added then.
