Hi there,
Apple recently released Google Workspace federation for Apple Business Manager.
I'd like to know if Meraki has any plans to implement a means of locking download Apple ID/iCloud sign in for work devices to for example only allow @Work.com domains to be used to login to Apple ID with or any other means to lock it down so that the end user cannot use a personal Apple ID and have client data backup to their personal account instead of the federated corporate account domain/email.
There is currently no way of tracking this on Meraki Management.
Solved! Go to Solution.
@_aDiedericks in System Manager > Manage > Settings
If you create a profile and select restrictions in there under device functionality is the "Allow modifying account settings" option if you leave this unticked users cannot make any account changes on the device i.e. iCloud, App store, email etc.
Hmm I think this is a question for Apple not Meraki, I don't recall seeing the ability to do this on Jamf.
https://community.jamf.com/t5/jamf-pro/restrict-icloud-to-corporate-accounts-only/m-p/177088
The only way to achieve this is to use managed apple IDs, which is currently only achievable for User Enrollment and Shared iPad enrollment types
Outside of these use cases, you can only BLOCK the ability to Manage account settings, including Apple ID
As @BlakeRichardson mentioned, this is an Apple limitation not Meraki
@PaulF Hi, thanks for your response. Could you confirm which setting allows us to Block end user's capacity to manage account settings?
