App scoping with multiple VPP accounts
Tapas
Hello, I tried to search for this but could not find an answer. If I have School Manager with multiple VPP accounts, how can I choose which account's licenses are used when installing apps in Meraki SM? When adding an app, all of the accounts with licenses are listed, but I can't seem to select which I want to use. All of the devices are in same network. Thank you!
6 Replies 6
Tapas
Hello again, in Organization -> MDM -> Apple VPP Accounts there is option to limit the "Assignable networks", so if I want to achieve my goal, must I have own network for every school and then I can allow a VPP account per network? This feels a bit overkill..
vassallon
@Tapas I know when I set up an App to push out in a Network you get to choose with account it will pull from.
BlakeRichardson
@Tapas if you have a VPP account for every school you would be better having an entire Meraki Org for every school rather than a network otherwise things will get very messy and confusing quickly.
Tapas
@BlakeRichardson Thanks for the reply! What would be the biggest problems or confusions doing this, can you specify?
Tapas
@vassallon Sorry, I tried to search for this option, where is it at exactly?
vassallon
@Tapas
It is on the App page under import:
Select the option for licensed iOS apps.
