App Licences not uploading to Meraki since purchasing within Apple School Manager
SimonA1
Our school has recently changed to purchasing all apps within Apple School Manager. Since then, the licences are not loading into Meraki.
We do have multiple locations, but I believe they all refer to the same place. The additional locations were probably created in error.  At some stage we need to remove the 3 non-used ones. I believe I have tested transferring the licences between all the locations to determine the correct one. This hasn't made a difference.
Our tokens and certificates should be up to date and I've tried doing a "force sync now".
Apps to appear on iPad, but Meraki still thinks there are no licences.
BlakeRichardson
@SimonA1  Have you uploaded the new ASM VPP token to systems manager?
MDM's only support dealing with one ASM location.
We run SM to iOS devices and Jamf for MacOS devices, we have a location for each in ASM.
2 Replies 2
BlakeRichardson
SimonA1
@BlakeRichardson Thanks. It possibly was a token issue. I've now got all the new apps to appear in the VPP Meraki Dashboard.
