Android Location Services
Totran_Admin
Is there a way to stop users from disabling Android location service on there tablets and phones.
5 Replies 5
PaulF
Meraki Employee All-Star
You can hide the settings application (Use the Android System Apps payload) but that doesn't stop the user from using shortcuts to turn off location
A limitation of android, sadly
KFoster
It's too bad the SM app does not automatically enforce those settings from a policy, which would thwart the end-user from modifying those permissions long-term.
PaulF
This is a limitation of the Android Enterprise API: There's no ability for us to prevent users turning location on or off.
Totran_Admin
Is this something Meraki is going to address in its development?
I believe from @PaulF's reply that the limitation is from the Android side, not the Meraki side.  Unless you know of another MDM solution that does force it?
