AD Auth stopped working
OhYou_
Hello all,
I've been using AD Authentication through a SM agent method for quite a while without issue, until this week.
I am no longer able to, the apple phones give the generic login info wrong or missing error.
I at first tried restarting the SM agent on the workstation with no luck, eventually moving it to a VM with the agent installed.
Still no luck, so I installed wireshark on the VM and monitored LDAP port 389. Checking the connection configuration status on the dashboard gives a authentication test was done, shown by wireshark. Annoyingly in cleartext I might add.
But when attempting to authenticate from multiple phones, no traffic.
Is anyone else experiencing issues? Is this an issue with Apple DEP, or with Meraki?
5 REPLIES 5
Re: AD Auth stopped working
The odd time I have had a problem a restart of the AD controller made it come right.
What machine is functioing as your AD proxy?  Have you tried rebooting that?
https://documentation.meraki.com/SM/Device_Enrollment/SM_Enrollment_Authentication#Active_Directory_...
jared_f
Also experiencing a similar problem. It seems Meraki doesn't like having to DC's plugged in or it throws off the sync. I removed one DC and re-synced AD groups and it seemed to have solve the problem.
GavinMcMenemy
Hi Philip,
I have a supplementary question.
My colleague has set this up for us. He's not in the office at the moment.
How can I tell which machine is doing this work?
I've found where the Domain Controllers are specified.
I'm going to create a separate thread as I suspect my issue is different.
GavinMcMenemy
Our AD authenticaion via AD is also not working.
