Cisco Catalyst replacement
And here's another smaller project, replacing Cisco Catalyst 2960S/X and Cisco 2802E with Meraki. In addition, a few sensors and a camera were installed. The migration to Meraki was so relaxed, it's crazy. Since everything could be built in parallel, the only thing that was really work was patching the ports.
Here is the MS225-48LP, primary for VoIP devices and APs. You may also see the old 2960S and some other old stuff^^.
And here is a MS125-48LP for lab use, nothing special.
Inkedimage-750cdfc5-c662-4686-91fc-e081027177c45259588704850400513 (002)_LI.jpg
MK2
Comments
Inderdeep
@MK2 : Awesome
MK2
Thank you. As I said nothing special. it's really great that here some post their projects. That's the real life 🙂
