Security Device Throughput
DanT
I'm wondering what the throughput of the Security device is. It looks like a rebadged Z3 which only has throughput of 100 Mbps. Anybody seen a datasheet?
Dan
GoJoe
Hey @DanT ,
The GX has a maximum throughput of 250Mbp/s. The datasheet can be found here.
GoJoe
Hey @DanT ,
Talon
Does it throttle to 250mbps or does not enforce this limit?
wave1Systems
Just browsing
Exactly what does that mean?  That even though I have a 1G connection from my ISP, will only only see 250M download speeds, or is it a limit of data rate between a wireless device and wired device on the internal network?
