Does the GX20 support multiple WAN ports (like the MX does) and does the USB support cellular failover?
Solved! Go to solution.
At this time the GX20 does not support those features.
Meraki Support
Hi @Al_S !
At this time the GX only supports one WAN port and does not support cellular failover. We would encourage you to submit a feature request via the app by submitting feedback or in the make a wish section of the community!
Hello... it's been 2 years. Has Meraki added support for multiple WAN ports and the USB support cellular failover? If not, is it on the roadmap?
What is the USB used for if not for failover?
The USB port is for a cellular modem if the feature becomes available for the GX in the future
@Al_S - The USB port allows you to utilize the local status page for the GX device.
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Using_the_Cisco_M...
Is USB cellular failover now supported?
