Multiple WAN ports
Al_S
Multiple WAN ports
Does the GX20 support multiple WAN ports (like the MX does) and does the USB support cellular failover?
MarvinX
Meraki Alumni (Retired)
At this time the GX20 does not support those features.
Meraki Support
7 Replies 7
AMP
Hi @Al_S !
At this time the GX only supports one WAN port and does not support cellular failover. We would encourage you to submit a feature request via the app by submitting feedback or in the make a wish section of the community!
Knowledge is power
Al_S
Hello... it's been 2 years.  Has Meraki added support for multiple WAN ports  and the USB support cellular failover?  If not, is it on the roadmap?
MarvinX
Meraki Support
Al_S
What is the USB used for if not for failover?
AMP
The USB port is for a cellular modem if the feature becomes available for the GX in the future
Knowledge is power
JamesMW
@Al_S - The USB port allows you to utilize the local status page for the GX device.
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Using_the_Cisco_M...
James Wilson
Cisco Meraki
ShaileshPatel
Is USB cellular failover now supported?
