Meraki Go - Network Error - Unable to view switch ports
PSF
I need to make some vLAN changes on my Go switch (24port PoE) and when attempting to view all ports, I get the error:
Network Error
There was a problem with that request, try again and contact support if the problem continues.
Retry / Cancel
I've waited a period of time (a day) and the issue persists.  Any help?
(I'm also not seeing any devices, application data, etc.)Meraki Go Error.jpgMeraki Go Error 2.jpg
2 Replies 2
TonyNg
Hello PSF,
We see that you are having an issue making changes to your Meraki GO switch.
To get a better understanding of the issue, can you let us know if you are experiencing the issue on the mobile app (iOS/Android) or the web app (https://web.meraki-go.com/)?
Can you try making the changes on the web app (https://web.meraki-go.com/) via a browser's private/incognito mode?
Best Regards,
.ılı.ılı. Tony Nghiem
Cisco Meraki Technical Support
PSF
Thanks Tony -
It's both app and online (multiple browsers and two ISPs that I have immediate access to).  I've added a secondary admin and some of the issue, not all, occur with admin 2 as well.  I've got a ticket open and am working with support.  I've had this before, it was a few years ago.
