- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Meraki Go Indoor WiFi Access Point - GR10 and - GR60
Dear Sir,
What is transmit power for the Meraki Go GR10 and GR60, both indoor and outdoor. Also what is the coverage area.
Thanks and best regards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @ehsan230564
My apologies for the delayed answer. The transmit power is, by default, automatically set using the Meraki auto power algorithm. This algorithm attempts to find the best operating wireless channel for client devices. Changes to transmit power and channel can be performed manually from within the mobile app.
The coverage area for the GR10 is approximately 500 square feet, but your mileage may vary depending on the environment. The same antennas are in the GR60, given similar propagation and distance properties.
Datasheets for each access point can be found here:
https://documentation.meraki.com/Go/Meraki_Go_Indoor_WiFi_Access_Point_-_GR10_Datasheet
https://documentation.meraki.com/Go/Meraki_Go_Outdoor_WiFi_Access_Point_-_GR60_Datasheet
