- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Custom DNS Addresses GX20
Hi all,
I was wondering if anyone knew a way of adding custom DNS settings to the GX20? I would like to use specific addresses if possible.
Cheers,
Stu
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Version 2.10.0 is now available in both stores.
- The Meraki Go App is now additionally available in Portuguese, Dutch, Korean, Russian, Chinese, and Polish
- You can now update which DNS servers get provided to clients by your Meraki Go GX
- Fixed a bug where you could not add an excluded URL on your security subscription settings
- Fixed a poor UX with changing accounts
Cisco Meraki
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@StuKoalaIT - if you are on the settings tab of the navigation bar, then under the advanced settings section you will see Local network addressing. You can click "Reserved IP addresses" and configure from there.
James
Cisco Meraki
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
James I can't see the custom DNS settings under the reserved IP addresses, it only gives me the option to enter the IP range details.
Cheers,
Stu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@StuKoalaIT & @Roska - Sorry for the confusion. Custom DNS settings on the GX are not yet enabled on Meraki Go.
We did however just release 2.6.0 to both the app and play stores which includes "Security Policy Selection" on the optional Meraki Go Security Subscription.
Cisco Meraki
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Ok thanks, quite a pace you guys have. Seems that the 2.6 version in not available in my country app stores yet.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@JamesMW wrote:@StuKoalaIT & @Roska - Sorry for the confusion. Custom DNS settings on the GX are not yet enabled on Meraki Go.
@JamesMW But it would possibly be in the pipeline for the future? I'm curious since I have Umbrella Insights in use and for now I have to install the agent on every endpoint. For some of them agents are not supported so they are not protected with Umbrella.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Cisco Meraki
