Google Home
jasonmcconachie
Google Home
Currently trying to set up a Google Home using MR 33 + MX 80 and a MS 120 8 port switch. I have opened everything up and not blocking anything to get this set up, however event though I can see the device (Google Home) on the network, I cannot get the app (Google Home app on my phone, on the same network) to see it.  Any thoughts on this? Is there some protocol that may be blocked? I can see the multicast traffic when I do a packet capture, but I can't figure out what is happening and why it won't connect.
2 Replies 2
home and phone are on the same ssid? is your ssid in nat or bridge mode? you checked the mr l3 firewall and l2 isolation setting?
I use "Google Home" and have and MR33 without issues.  "Google Home" is a whole set of devices.  I have both wired and wireless "Goolgle Home" devices.
Make sure the SSID is using bridge mode (as mentioned by @jasonmcconachie .  Don't use a domain name ending in ".local" (in case you have a DNS zone configured on your DHCP server).
If you are trying to talk to a wired Goolge Home device make sure your MR33 firewall rules allow local LAN access.
https://documentation.meraki.com/MR/Firewall_and_Traffic_Shaping/'Deny_Local_LAN'_settings_in_Cisco_...
Make sure you are not using wireless client isolation.
https://documentation.meraki.com/MR/Firewall_and_Traffic_Shaping/Wireless_Client_Isolation#Example_S...
Are all your Meraki devices running "current' firmware versions?
Meraki Insight forum closed
This forum is now closed. As of July 26, 2024, Meraki Insight licenses are no longer available to purchase. MI functionality is now included in the SD-WAN Plus or Per-device SD-WAN Plus licenses. You can view more information about this on our End-of-Life Products and Dates page, Product “LIC-MI”.
Please ask any questions about MI-related functionality in the Security & SD-WAN board.
