Hello together,
I want to check the internet connection on a few MS225-24P.
The ISP told me, that there is no problem from their side and it has to be an internal problem.
Is there a way to do something like a speedtest from the switch itselfe?
If yes, is it possible to do this test every 30 min and save the outcome in a log file?
I just want to do that for 24h.
Thanks,
Timo
