Dear CN
Put temporary manual NAT traversal in order to force all VPN to change ports can be an other work-around, but it still not an automatic fail-over.
In this case, why Meraki can not change source port used when a new public IP is discovered? (this could solve other behavior I saw too... because dynamic NAT behavior change a lot depend of routers models)
The intricacies on Palo side is the fact that because the source IP (Private VIP IP from the one armed concentrator) and the source port don't change on this fail-over, the Palo-Alto continu to work with the same session and continu to NAT of the old public IP. So all incoming packet coming from other MX on the new public IP are drop because there is no existing session on this criteria.
Clear session or change source port will force to recreate these sessions.
I continu to think this behavior is not normal on Palo side.
An other work-around I had in mind was to have an incoming rules to allow UDP flow to go to the VIP MX IP.
But this kind of incoming rules looks not good in term of security and Meraki don't recommend this rule in this configuration. Do you think this could be a way?
Best regards,
