- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Meraki Full-Stack Design Related Question - Dropping Untagged traffic
What concerns would you have when removing VLAN 1 entirely from a Meraki MS/MX/MR network and dropping untagged traffic across all interconnections (trunks)?
I know there are some requirements to keep VLAN 1 as native VLAN in a mixed Meraki/Catalyst/Nexus environment, so this question focuses on Meraki hardware only for discussion sake.
To meet network security best practices I often wonder, why not remove VLAN 1 from the MX, tag all the subnets across the MX LAN ports to MS switching and configure all the trunks to drop untagged traffic.
I don't see any issue but have heard sometime dropping untagged traffic could cause problems, I just haven't seen these problems myself.
Thoughts? Opinions?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Where did you hear that statement? I needed to drop in some specific cases and never had any issues.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Which statement? Assuming the statement about keeping VLAN 1 - The link RaphaelL shared is it.
I have seen issues in the field with this though - a lot of issues in mixed vendor environments due to STP where there are rapid STP Per Vlan instances of spanning tree running.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
""I don't see any issue but have heard sometime dropping untagged traffic could cause problems""
despite what the documentation says I can't see this as a problem, but ok.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If you set a VLAN as native and don't include it in the trunk and do the same on a Cisco Catalyst switch at the other end, then the link will not pass the traffic in the native VLAN, I can confirm this from experience...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
the stp is using a native vlan. So as long you make sure you never have a loop (by the network admin/user error), and dont want/use redundancy based on stp blocking on your network, it should work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This will prevent spanning tree packets from being forwarded and may result in an incorrect spanning tree being formed.
