- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
MX250 using 2 different ISPs on WAN1 and WAN2, how do I set this up?
We are a school serving almost 1300 Students and 150 staff. We currently switched our ISP from charter to Spirit Communications. However, we have a space in our building that we rent out, and provide them with internet (which they reimburse us for a portion of that internet access.) However, now that we have switched to Spirit (which we get discounts through E-Rate) we can not alow this third party to utilize the services from Spirit.
Therefore, we need to have Spirit on WAN 1 (providing internet to our school) and put Charter on WAN 2 (for the 3rd party company). I have not found a way to set any ISP IP addresses, subnet, gateway, etc for WAN 2, so I am guessing I will need to do some sort of VLAN Addressing, but I have not found a way to set anything for WAN 2.
So To recap, I need WAN1 to remain SPIRIT and WAN2 to link with Charter, while WAN1 and WAN2 remain separate and unable to see each other on the network.
Any Advice is appreciated!
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Put the space you rent out into a seperate VLAN (and hence subnet).
Use traffic flow preferences to set that subnet go out a specific WAN circuit (under Security Appliance/Traffic Shaping).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Realized I had to put "Any" in Destination instead of leaving it blank
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hey Phillip, I have another question about this one....
Under Routing, What do I put as the MX I.P. for my leased out internet, on WAN 2, using a subnet of 10.20.0.1/20? I tried using the true IP address of the MX and it threw an error....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Under routing? Where are you seeing that heading?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I put the subnet in as the MX I.P. for now so I could save it..... If I try and put the actual I.P of the MX (172.20.0.1) it gives an error (which makes sense, because it is on the other VLAN)....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Each VLAN needs a unique subnet, and the MX should have a unique IP address in that subnet. What you are showing is fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I guess Im having an issue understanding the purpose of the MX I.P then....
I only have the one MX250 and it has an IP of 172.20.0.1
So how is setting VLAN 2, with an MX IP of 10.20.0.1 going to do anything? 10.20.0.1 doesnt actually exist, I just made up that subnet....
Also, currently, the MX250 (172.20.0.1) is acting as the DHCP server. With this is mind, and having Charter traffic go across WAN 2, how will they get IP addresses in to 10.20.0.1/20 ranges?
Maybe this is a case of a lack of understanding on my part, of how this works ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You need to plumb this third party into VLAN2. You can do this via VLAN trunking, or plug them directly into some ports in VLAN2.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Okay, yeah that makes sense.
I plan on tagging an empty port (19 i think) as VLAN 2. That port will lead to all the AP's and hard lined devices that will be using the Charter internet.
So what you are saying,(correct me if im wrong) is that once I make that physical link, and tag that port as VLAN 2, the current settings we talked about in above replies, are good to go and the Clients that will be using Charter should be good.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
On boarding 2 ISPs on MX 250 shall not be a challenge. All models of Meraki MXes support 2 WANs.
This can be configured from Local Status Page of the Hardware ( Connecting a PC to Management Port).
I am sure you know about this.
Now segregating WANs each for 2 different organization.
One idea shall be to take the advantage of “Traffic Shaping” Feature [Security Appliance->Traffic Shaping]. You may create 2 different subnets on MX250 and with the help of Internet Flow Preferences can route the Traffic to desired WAN.
You may configure L3 Firewall rule to deny any communication between the subnets [Security Appliance->Firewall].
However I believe if one the Link fails all the traffic shall move on to the active link.
Ajit
AjitsNW@gmail.com
www.ajit.network
