MS120
Enrico_Romero
MS120
Hi Team,
One of our Client's is requesting for an MS120 model. However it's not yet order-able in Cisco Commerce Workspace (CCW) since its will arrive this Fall of 2017.
Is there a possible alternative if this is an urgent request?
Thanks in advance!
Regards,
Enrico
There is only one alternative - the existing MS225.  If you are lucky you might be able to talk your local Meraki rep into giving you a bit more discount, especially if the customer is already using Meraki.
5 REPLIES 5
Depending on how many ports you're after you might want to ask about the MS220-8P. As per @PhilipDAth's comments reach out to your Meraki sales rep, they'll be able to sort you out.
are we expecting the MS120 to be a lot cheaper?  The MS225 is quite expensive with the 10gbit and all that.
@soomeGUy yes, we are expecting the MS120 to be quite a bit cheaper than the MS225 because they don't have 10Gb/s connectivity.
couchbob
MS120 is as of today orderable!
Comes in a number of variants, the 8 port is available as full PoE or half PoE variant. Also 24 and 48 ports of course with or without PoE.
