We are looking to connect our MX100 to a MS250 stack using a SPF cable however the unit I purchased ( #10Gtek# [2-Pack] 10G SFP+ DAC Cable - 10GBASE-CU Passive Direct Attach Copper Twinax SFP Cable for Cisco SFP-H10GB-CU0.3M, Meraki MA-CBL-TA-0.3M, Fortinet, Ubiquiti UniFi, D-Link, 0.3-Meter(1ft) - https://www.amazon.com/gp/product/B09BF98YRQ/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&th=1 ) does not seem to be working. I know the cable is working because when I connect from our MX250 to an older Cisco 2960-x, it lights up and has connectivity but when I try it from the MX to the MS it get nothing. Is there a setting I could be missing to make this work or do I need another cable? Apricate any suggestions to point me in the right direction.
Hello @ww , Yes. I have the cable currently connected between the MS250 and the 2960-x and it is working. I had also previously tested it between the MS switches also. So I wasn't sure if there was something different with the MX100.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_69d0e275f654b9","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_69d0e275f654b9_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_69d0e275f654b9_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_69d0e275f654b9_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_69d0e26c637d45","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
