iOS Passcode length policy not working
I have this problem for years. Devices are supervised, I created a settings and what to allow 4 digit passcode, this is what I setup.
Minimum length 2 or 4... is not working, the user must enter a 6 digits passcode, on the device, user doesn't have the option to go from 6 to 4 digits as a none MDM device do.
Is there another settings somewhere else, maybe in restriction, that cause the behaviour ?
Thank you,
JF
3 REPLIES 3
Re: iOS Passcode length policy not working
I believe this is an Apple-enforced restriction on the newer versions of iOS. See here:
https://arstechnica.com/gadgets/2015/06/apple-to-require-6-digit-passcodes-on-newer-iphones-ipads-un...
no, by default it set to 6 digits, but you can choose to have 4.
My device running iOS 13.3, my wife is running on a 4 digits since iOS9
it's french, but allow me to choose 4 digits passcode.
I just update an old iphone7 ready to give to a new employee, the old device was off for +6 months, when I open it, the 180 day change code policy ask my to change it, it was 4 and only 6 was possible now. It still run iOS 12.x
if I remove the passcode policy settings from the phone, I can set it to 4... so definitely it has to do with this MDM settings pushing something wrong!
I was with another MDM supplier before, never had this problem.
thanks
@Adam2104 That is a very old document, 4 digit passcodes can be used on modern devices, most of ours have 4 digit codes and the hardware is 6th and 7th Gen iPads.
@jffortier If your policy isn't working as expected and have have set minimum passcode length I would contact support, below is a screenshot of my settings that are working for me.
