Search instead for
Mojave 10.14 and the new Privacy Preferences Policy Control payload
Hey everyone! If you've been testing the Mojave betas you might have encountered these new privacy permission alerts in Mojave (example screenshot below). Until Meraki releases an update with a payload template, check out this awesome tool that a kind soul at Jamf made. You don't need Jamf for this to work, just export a .mobileconfig and upload to your Meraki dashboard.
https://github.com/jamf/PPPC-Utility
7 REPLIES 7
Re: Mojave 10.14 and the new Privacy Preferences Policy Control payload
Awesome thanks for sharing this
Thanks for sharing!
I created some app whitelist profiles if anyone wants to be lazy Smiley Happy
https://github.com/ducksrfr/mac_admin/tree/master/Privacy%20Preferences%20Policy%20Control%20Profile...
Could this be the reason for why installing apps with the meraki agent fails in Mojave? Do we need pppc profiles both for the meraki agent and the app it is trying to install?
Regards,
Thomas
@eritho It's definitely possible that m_agent needs to be added to the profile, but not necessarily each app it's trying to install. I recently started a new gig (that doesn't use Meraki) so I don't have immediate access to the Meraki dashboard any more to test.
I would recommend starting with allowing m_agent access to SystemPolicyAllFiles, as well as 3 AppleEvents that whitelist control of Finder, SystemUIServer, and System Events.
https://help.apple.com/deployment/mdm/#/mdm38df53c2a
Thanks for the reply @sshort.
Have you been able to locate the m_agent app and create a PPPC with the PPPC-Utility? I can´t find the application on my computer, the only thing i can find is some safari.webkit-somthing that is connecting to meraki but my lack of skills stops me from doing anything usefull.
@eritho I would start with the binaries you find in the locations below. just drag into the PPPC Utility
/usr/local/sbin/m_agent
/usr/local/sbin/m_agent_upgrade
Points Contest
Join us for a month-long contest with heaps of swag to win!
Learn More ›
