Search instead for
Discovered A New Feature Connection Log
This is pretty awesome ,  besides the obvious of troubleshooting connection this will also help with Stolen devices
Re: Discovered A New Feature Connection Log
Hi Mike,
where exactly in the Dashboard did you find this Log?
Pick a Asset/ Device and scroll down you should see it
Found it.
System Manager --> Device --> select a device and scroll down :-)
Thanks a lot
@Mike_YMCAMIDTN I saw that myself the other day. I just question how often it updates. With Meraki APs and devices that are managed by Meraki. I would sure love to see the iPad's connections throughout the day and see which APs the device is connecting to see if anything unexpected is occurring throughout the day.
I'm already testing that with hotspots
I just did a Test and it is quite fast about 1 Minutes after connection to the Public Hotspot:
Important to know i had the System Manager App on my IPhone open!
