SecurePort
SecurePort
The SecurePort documentation could do with a refresh.
https://documentation.meraki.com/MS/Access_Control/SecurePort_(formerly_known_as_SecureConnect)
Are the C9300s supported?  What about the MS130X switches?
Is it possible to tell from the dashboard if SecurePort has "kicked in"?
This post has some information about how to monitor SecurePort from the dashboard (which would be good to get incorporated into the documentation):
https://community.meraki.com/t5/Feature-Announcements/New-name-same-great-feature-MS-and-MR-SecurePo...
Ryan_Miles
@PhilipDAth  As far as I know the list of supported Switches in the doc is accurate today. There are plans to bring more functionality to the C9300-M. Not sure if it will come to the MS130 family.
As for how SecurePort looks in dashboard. When a switchport has successfully authenticated a Meraki AP it will show a Wi-Fi bars icon on the port. If it fails to auth the AP the port still shows the Wi-Fi icon, but the port would be red. I don't recall if there's a state in which it would be amber. I'm not finding any failing ports in my searching to confirm.
Clicking on the switchport will show you that it's been authenticated by a SecurePort profile.
And clicking on the config comparisons link will show more detail.
I agree with you that adding screenshots like this to the doc might be helpful. Thanks for the suggestion. I'll forward it along to the doc folks.
Ryan
KH
Hey @PhilipDAth
To close the loop here, I have updated the KB with screenshots of the different states/errors to make it more clear when it has kicked in.
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
