Hi ,
There is 2 documents that I would like to get some clarification about :
https://documentation.meraki.com/MR/Access_Control/MR_Meraki_RADIUS_2.0
Section Called Station ID is missing 2 attributes :
AP LAN IP
AP Public IP
NAS ID
Should reflect the warning present on the dashboard about 802.11r. Some attributes are not available if 802.11r is enabled :
Device IP set as NAS-ID
I'm currently running a MR36 with MR30.7 firmware and I do have the attributes AP LAN IP and AP Public IP .
Unsure if the notice is correct :
With MR31.1 the NAS-ID value can be set as the AP’s Public or LAN IPv4 address.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring_RADIUS_Authentication_...
I'm not sure this is correct. Taking a packet capture of an auth request with a SSID configured with "My Radius server" shows a Called-Station-ID of : NODE_MAC:SSID and not the BSSID:SSID
Cheers ,
