Hi ,
This document needs to be revised.
https://documentation.meraki.com/MS/Access_Control/MS_Switch_Access_Policies_(802.1X)
1- This feature is GA.
Organization-wide RADIUS servers
Org-wide RADIUS servers are currently in Early Access Preview. Refer to the Organization Settings document here for more information on how to define and use RADIUS server configurations at the organization level.
The Org-Wide RADIUS servers feature provides the ability to define one or many RADIUS servers once and then re-use the configuration across the organization for access policies.
2-
Increase Access Speed
Seems to have been renamed "Concurrent Authentication". Should be documented
3- Long list of SKUs :
(Supported on MS210/225/250/350/355/390/410/420/425 and C9300-M). Would it be simpler to note which SKU is not supported instead ? Seems to be missing at least MS130.
4- This feature is available in public preview/beta in dashboard as of Aug 2022 beginning in MS 15 for classic switches. The toggle will only appear on networks running MS 15 or later. Support is not available on MS390 switches as of MS 15, but is anticipated to be added in an upcoming release.   Should probably be removed since GA.
5- Optional : Refresh the screenshots with the new UI. Some fields have been moved / renamed.
Sincerely ,
 The Bookworm.
