We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
I am trying to configure MX Access Policies via the API and need to set the radius servers(MX Access Policies (802.1X) - Cisco Meraki Documentation)When you configure a port, I think you need to use the updateNetworkAppliancePort ( https://developer.cisco.com/meraki/api-v1/update-network-appliance-port/ )This however does not provide any properties for the radius servers.. How do you set the radius servers.
As far as I can see you must do that in the GUI. There is no available API to do that at this time. That feature is limited to the MX6X models so I'd guess it's not a priority for the team.You can always submit feedback: https://documentation.meraki.com/General_Administration/Other_Topics/Give_your_feedback_(previously_... and/or contact your account rep if it's of importance.
check this one
https://developer.cisco.com/meraki/api-v1/get-organization-auth-radius-server/
It seems they are asking about MX which as far as I know doesn't use org wise radius.
yes, have a solution for MS Switches, but MX is a bit differnet.
