integrate tools with Meraki SD-WAN to enable automated incident creation, alert routing
KD007
I'm exploring options to integrate tools with Meraki SD-WAN to enable automated incident creation, alert routing, and escalation. The goal is to streamline incident management and integrate alerts with our ticketing system for a unified workflow.
2 Replies 2
MartinLL
Check out this thread. In the posted solution you can find some templates and alert settings you can use with webhooks.
https://community.meraki.com/t5/Dashboard-Administration/Custom-webhook-templates-are-network-specif...
Depending on your ticketing system you might need to write a reform script that maps key value pairs from meraki to values your ticketing system understands.
The example in that thread is for Service Now.
https://documentation.meraki.com/General_Administration/Other_Topics/Webhooks
MLL
Prodrick
If you happen to be looking for a packaged solution that does this, I suspect that most if not all of the Performance Monitoring products on the Meraki Marketplace do this.
https://apps.meraki.io/en-US/listing?cat=99861
Disclaimer: I work for one of these companies, but I imagine our rivals have similar ITSM and workflow integrations.
