{"logs":[{"DEBUG cmp.magnetic-navigation on 2025/03/06 03:43":{"core.restRequest()":{"query":"/categories/id/Choosing-Your-Ideal-MT-Sensors/nodes/count?restapi.response_format=json&restapi.response_style=view&restapi.format_detail=full_list_element&message_viewer.topic_sort_order=last_post_date&message_viewer.message_sort_order=thread_ascending&nested.page=1","error":"REST Error:\\n path=\\\"https://community.meraki.com/yuzje69629/restapi/vc/categories/id/Choosing-Your-Ideal-MT-Sensors/nodes/count?restapi.response_format=json&restapi.response_style=view&restapi.format_detail=full_list_element&message_viewer.topic_sort_order=last_post_date&message_viewer.message_sort_order=thread_ascending&nested.page=1&restapi.response_style=view\\\"\\n status=\\\"error\\\"\\n code=\\\"101\\\"\\n message=\\\"No category with the specified dispid.\\\"\\n\\n----\\nFTL stack trace (\\\"~\\\" means nesting-related):\\n\\t- Failed at: #local response = rest(query) [in template \\\"core.ftl\\\" in function \\\"restRequest\\\" at line 2241, column 49]\\n\\t~ Reached through: #nested [in template \\\"core.component.ftl\\\" in macro \\\"cmp\\\" at line 77, column 33]\\n\\t~ Reached through: @cmp o={\\\"debug\\\": false, \\\"debuginfo\\\": ... [in template \\\"cmp.magnetic-navigation\\\" at line 6, column 1]\\n----"}}}],"errors":[{"ERROR cmp.magnetic-navigation on 2025/03/06 03:43":""}]}
getOrganizationSensorReadingsHistory change in return data structure for MT14
sungod
The return from https://developer.cisco.com/meraki/api-v1/get-organization-sensor-readings-history/ for an MT14 used to include an element called 'readings' that contained an array of readings.
See... https://community.meraki.com/t5/Developers-APIs/Need-MT14-example-response/m-p/153770
I was testing all my scripts today following some general tidying up of how missing device names are handled following other recent API return changes, and I found the return for MT14 no longer includes this element, instead the readings have been unbundled.
This is more consistent with other sensors, but is a breaking change as my script expected this element.
New behaviour of call returns one reading per MT14 metric, instead of an array of all readings at time ts.
{'serial': 's', 'network': {'id': 'a', 'name': 'b'}, 'ts': '2023-08-29T01:21:45Z', 'metric': 'eco2', 'eco2': {'concentration': 668}}
{'serial': 's', 'network': {'id': 'a', 'name': 'b'}, 'ts': '2023-08-29T01:21:45Z', 'metric': 'indoorAirQuality', 'indoorAirQuality': {'score': 100}}
{'serial': 's', 'network': {'id': 'a', 'name': 'b'}, 'ts': '2023-08-29T01:21:45Z', 'metric': 'tvoc', 'tvoc': {'concentration': 220}}
{'serial': 's', 'network': {'id': 'a', 'name': 'b'}, 'ts': '2023-08-29T01:21:35Z', 'metric': 'humidity', 'humidity': {'relativePercentage': 54}}
{'serial': 's', 'network': {'id': 'a', 'name': 'b'}, 'ts': '2023-08-29T01:21:35Z', 'metric': 'temperature', 'temperature': {'fahrenheit': 69.4, 'celsius': 20.78}}
I wondered if I missed an announcement, but I searched and didn't find anything about this change.
2 Replies 2
John_on_API
sungod
Different API call, but yes it looks like a similar change.
It's great that return structures are being made more consistent, but as in the other post about device info, it'd be useful if there was some place these changes were notified or at least documented.
I've now hit three different calls where a return structure change has broken automated reporting scripts and each time I've had to drop other things to investigate, fix, test and deploy. If there are more coming, it'd be much better to have some warning.
