getDeviceAppliancePerformance Returning 204 - No Content
giovanitestoni
Hi everyone,
I’m encountering an issue with the getDeviceAppliancePerformance endpoint of the Meraki API. Until last month, it was working perfectly, but now it’s returning the HTTP status code 204 - No Content.
The expected behavior of this endpoint is to return performance metrics for a specific device, but it now returns an empty response.
Has anyone else experienced this issue recently? Was there any update or change to this endpoint that I may have missed?
Any guidance or suggestions would be greatly appreciated!
giovanitestoni
I opened a case, and support tell me that this issue is known and they are working for a fix.
There is no ETA at the moment.
8 Replies 8
Can you share your code please?
giovanitestoni
Hi!
My code is the same as the documentation:
https://developer.cisco.com/meraki/api-v1/get-device-appliance-performance/
The script started to return an error because the response needed to be Numerical/Float and None is a String.
GreenMan
Meraki Alumni (Retired)
Generically, this endpoint seems to be working OK for me, through a single call
RaphaelL
You should avoid "device" specific calls and use this one : https://developer.cisco.com/meraki/api-v1/get-organization-summary-top-appliances-by-utilization/  You can use any value for quantity
giovanitestoni
With the timespan < 44000 the return is None too.
giovanitestoni
I made some tests and the code works when I put the timespan > 44000, normally I use the default value. The default is 30 minutes.
giovanitestoni
CarolineS
Community Manager
Community Manager
Hi @giovanitestoni -
I am going to mark this reply as the "accepted solution" for this thread. If you hear more info from support, please update us (and we can update the "accepted solution").
Cheers!
- Caroline
Meraki Community Moderator
