Why NOT ALL clients returned? Even if Online.
AidanVenn
Hi All,
When I run:
url = "https://api.meraki.com/api/v1/networks/xxxxx/clients"
My response only covers a random number of clients on the network. Lets say 10 of 100 wired and wireless, online/offline.
Each request returns the same clients but not all of them. Can be missing 50. They all appear in the Meraki dashboard.
Anybody else facing this issue or know of a fix? Maybe my interpretation but results show no patterns across the 2000 + networks we have.
thanks
the default is 10.
can you try with
perPage 1000
the default is 10.
can you try with
perPage 1000
AidanVenn
Doh!! Thanks ww for fast reply and solution!
sungod
You need to handle multiple pages of client details if you are using the 'raw' API.
If you use the Python SDK, it will do the page handling for you, for instance...
clients = await aiomeraki.networks.getNetworkClients(net['id'], timespan=t, perPage=1000, total_pages="all")
...can return many thousands of clients.
